B6100e Lift Arm
portshop
B6100e
Sep 18, 2012
Gold Beach OR
I broke a lift arm, ordered a replacement, ended up receiving a "kit" that includes both left and right arms & the shaft, o/p arm. My question is, has anyone in this forum replaced the shaft? The lift arms are fairly straight forward but the shaft, I'm not so sure. Thanks for your help.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
hi and welcome to OTT,
Yep it is pretty straight forward, but you'll need to take the lid of the rear axle casing as thelift arm shaft has an external expanding circlip on the shaft that you'll need toremove first before you can slide the shaft out of the lid.
take note of how it comes out , as it is possible to put the shaft coonecting rod back in upside down.
I have a diagram if you need it shown any clearer.
hope thats of some help.
rob
Rob
Nov 22, 2009
679
11
Leafy England....
allmost forgot to mention, if you look on the end of the shaft (both ends) , you will see a "dot" mark ,when you come to refit the arms there is a dot on each arm that you use to line up with the shaft, you can then be sure that they are on in the correct position.
rob
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
375
10
Homer City, Pa.
Just recieved my upgrade kit on Monday, the difference on the "old style" is that they were bolted when clamping to the spline, the "new style" is that they have a roll pin holding them on the spline, the bolted ones give out in time.
Big Kahuna
Rob
Nov 22, 2009
679
11
Leafy England....
heres the diagram ,doesnt show the rod but it shows the important bits.
rob
portshop
B6100e
Sep 18, 2012
Gold Beach OR
Okay, I asked for the drawing before I saw that you sent it.
I have that drawing, so don't go to the bother of sending it.
It's the removal of the circlip that appears to be the big problem.
I've taken some pics as I haven't been into this part of the tractor before.
Moving ahead. I'll keep this thread updated.
Thanks for the info!
Bill
