B6100 wiring issues
morson82
B6000E, 61" Scag
Jun 29, 2011
30
CT
Hey all, I have a b6100dt and am trying to reinstall the headlights and taillights and repair what has been hacked up, etc. I looked through the parts manual and found nothing of help. I am trying to figure out how to wire the lights so that the light switch will work, both wires off the switch go back into the wire harness. I am looking for some sort of schematic but I doubt if one exists. Anyone that has a suggestion of where I can find a schematic or if someone out there has a b6100 and is willing to take a few pics of the wiring under the control :confused:panel I sure would appreciate it!!
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
This is from the user manual
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
hi there,
I know what youre going through mate, i have been totally rewiring my B7100 as the whole loom had been hacked about and totally messed up.
I used to a have the diagram in my manual but it had been lost , luckily B7100(dave) emailed me copy which was great, but, the owners manual is not 100% accurate i'm afraid.
I've had issues with the optional alternator wirirng and loom config, also my wirirng colour codes for the lighting are not the same as stated in the manual.
In the end i just had to get my multimeter out and check every wire and compare notes with several wirirng diagrams to get it sorted.
I did speak to the tech guys at Kubota Uk about it, and, there does appear to be differences in the wirirng looms over the production run of the B7100's .
which includes the HST version also.
you'll probably have to use the same method as me, get the meter on the wires and trace them back to source/switch.
good luck, if youre stuck ,drop me a line and i'll try and help you through it.
cheers
rob
PS, big thanks to B7100 for his info..
morson82
B6000E, 61" Scag
Jun 29, 2011
30
CT
Thanks guys, now it all makes since!!!! Thanks for the help and schematic. I'll let you know if I run into any issues...:)
