b6000 front differential oil change/steering case
mdb6000
b6000
Oct 11, 2010
79
monroe, ct
Plan on changing the oil in the front diff. Is it pretty self explanatory? I see a drain plug, I see the fill plug, is there anything else I need to know? Also, what other oils do I need to change while I'm dealing with the front. I have read there are some other things up there that need oil changes? Just looking for clarification on that. Also, where the heck is the steering case oil? Thanks.
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
Alberta
The steering box is located at the bottom of the steering column. It has tiny drain and fill plugs.
mdb6000
b6000
Oct 11, 2010
79
monroe, ct
Thanks guys, changed those fluids, everything was right where you said, but didn't bother with the steering fluid, is that something that's changed normally? Thanks
freewheel3
Mar 9, 2013
333
Alberta
It doesn't need to be changed very often but I'd recommend doing it if you don't know if / when it was last done. If the tractor was stored outside much, there is a chance the oil is contaminated with water as they have a habit of letting rain water run down the column and into the gear box.
Its your call but its cheap insurance against steering box failure. IMO.
