B3350
B83
Fall Creek, wi
New member and owner of B3350. Not sure how to navigate this site
real smoothly so Hope I get some responses and am able to locate them
later.
I have read past notes from owners of the same tractor that have had
computer/DPF failures/problems etc.
Mine has 14 hours on it and is in the shop right now for those same issues.
The other posts I read never said if they have gotten a satisfactory repair
as of current.
My problem started with an engine warning light coming on within 45 min
of using the tractor for the first time.
Can anyone out there tell me if Kubota has found a permanent fix for these
issues.
Thanks.
8,120
Not sure about a fix. But i do have a question bout how the new kubotas are set up. Do they give you a way to see what the codes are when your check engine light comes on? Or do you have to take it to the dealer every time?
If it displays the codes, talk to your dealer and see if they can print you off a copy. Before i got certified in another brands engine controllers for work, i used to drive the local dealers mechanics and service manager crazy till they finally gave me a list of the codes. Some of the codes are simple common sense fixes, that a dealer can charge you back for like low fuel rail pressure, or water in the fuel seperator.;)
