B3000 HSD plain jane
john11139
L3400
Feb 18, 2018
21
Newark, Ohio
I have a Kubota B3030 and I guess they are all the same, (deluxe) except you can get the cold weather and rear wiper package but I am looking at a B3000 and I guess they made a model B3000 HSD. It doesn't have the adjustable lift arms, and does not come with the front over head cab lights, nor the arm rests on the seat. Can any one tell me if they install the wiring or not, or will head liner have to be dropped and does it have the bracket welded on to mount them? I think they made a B300hSD a HSDC and a HSDCC
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
104
24
Nampa, Idaho
I believe the wiring harness located between the cab roof liner and the cab roof will have the connections to add the front cab lights, rear cab lights and rear cab safety lights.
I also believe the front of the cab windshield will have a bracket welded in place that will allow you to mount your front lights to.
I have attached a picture of how I have hooked mine up.
In the rear of the cab I made two small angle brackets that I attached to the lifting brackets for the cab. I then attached my rear facing work lights and the outside safety marker lights to the angle brackets and ran wiring to connect to the wiring harness above the cab liner.
I also have attached a Picture of this setup on the rear of my B3000HSDC.
