FYI. Be sure to check the measurements with the output shaft coming from the PTO to the mid PTO driveline shaft. My output shaft came loose from the mid driveline shaft and it cost me $280 for a new output shaft! There are two 1/4" allen set screws on the front and rear bearing collars that the driveline shaft slide through. Three screws let go and the rear output shaft came loose from the spline of the driveline shaft.
The distance from the end of the spline on the driveline shaft to the edge of the bearing coupler is 5 3/4".
That leaves about 3/4" for the front driveline male to connect to the front spline of the midline shaft. The midline shaft slides between the rear and front bearing collars and can be adjusted to the proper setting. It will all make sense when you look at it. My dealer said to use blue locktite on the four allen set screws to assure they stay put. Clean out the holes with carb or brake cleaner to clean out the grease before using the locktite. I will be checking the 4 set screws before I blow snow in the future and I advise you to do the same!!!
