B2710 injector problem?
astoneburner
B2710HST 72 in deck loader
May 19, 2012
ohio
After tractor runs approx 30 min it develops a misfire.Tracked this to #1 cylinder.Let tractor sit a couple hours and fine again for 30 min.I am thinking injector issue.
hopefully not the pump
any ideas
thanks Alan
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Possibly fuel starvation which is usually caused by a plugged fuel filter, I'd change it just to rule that out. What makes you think it's cylinder one?
astoneburner
May 19, 2012
ohio
Cracked injector line open while running and made no difference in rpm similar to pulling a plug wire to locate miss.Fuel starvation should affect all cylinders and mainly under a load.I changed filter anyway.
Ordered new injector from Messicks today.
Alan
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Agreed it's probably not the filter. I assume you were getting good fuel at the injector bleeder? The injector's not a bad guess but kinda of expensive for guess and replace. If that doesn't do it the next thing to do is a compression\leakdown test on that cylinder.
gurn
Kubota L175
Apr 15, 2011
239
17
Nashville,Tn
For you're sake I hope its the injector. If so you could rebuild the old one for a spare. It probably just has some crud in it. Anyway, welcome to OTT.
astoneburner
May 19, 2012
ohio
My thoughts exactly on rebuilding injector for a spare.Have not done compresion test yet due to fact it runs so good for first hour and no crankcase blowby.Figured I would have new injector here before tearing old one apart.
I just bought tractor used about 3 weeks ago and was not expecting to see this type of problem with only 1350 hours on it.This is my first Kubota and so far I love it.
A big thanks to the forum for some good info for new owners of old kabota's
