B2650 tire issue
redleg105
B2650 with Snow Blower
Feb 27, 2022
12
My B2650 is a 2014 and I believe the rear tires are beet juice filled. One tire is leaking around the rim. What could be the problem? Thanks for any advice
GrumpyFarmer
4,557
I would guess either improper pressure (could be over or under inflated), bent rim or corroded. Unless you know you have a bent rim from something recent I would suspect it’s under inflated…when is last time tire pressure checked? ( could be a slow leak somewhere that would lead to low pressure…check tire pressure first)
redleg105
Feb 27, 2022
12
You were right. Both were low but only one was leaking. Filled with citrus juice
