B2650/B77 Dimensions Questions
PA452
B2650
55
Western PA
I have a few requests for dimensions.
One is easy and I think I already found it in old posts. That is, what's the length of a B2650 with FEL and 60" bucket resting on the ground to the back of the 3ph?
Two is also fairly easy, B2650 with FEL/60" bucket on the ground and B77 backhoe attached and swung to the side, what's the length? About 14'?
Three is a little more tricky. If I build a short dolly for storage of the backhoe, how much space will it take up, length, width, and approximate height assuming the dolly is an average height? I have an area underneath some industrial shelving and I'm wondering if it's possible to roll the backhoe underneath for storage. It's about 95" long x 36" wide x 26" high.
Thanks
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
I may be able to give you some of the dimensions you are looking for. Question 2 the dimension is 14' 3" but may not be exact as I have a B2650HSDC which has a cab. But I subtracted 9" for the extra mounting hardware that allows the bh77 to fit on the B2650HSDC . As far as the dimensions for the bh77 on a dolly, the dolly I built is 95"x 28"x 7" . It uses 5" casters. I don't have a total height with the bh77 on the dolly as it is currently on the tractor, but estimate the height to be 72" when stored on the dolly.
Hope this helps.
PA452
B2650
55
Western PA
Thanks, especially on the detached backhoe height. That's quite a bit taller than I imagined, but I really should have known at least that it wouldn't fit in that space I was thinking of. Even my BX23 backhoe when sitting detached on the ground is taller than 36".
Oh well, thanks.
