Greetings, my B2630 HST has the PTO stuck in gear and won't disengage. I've been under tractor and there is no debris in or around the shift lever or the lever on the valve assembly. Has been getting tougher to engage/disengage so thought at first might be that hydraulic fluid was low, which it was but topped up and still have issue. Attaching 2 PDF's. One shows the assembly the other shows how it's supposed to move. At the moment I can push it forward without resistance but pulling it back to the neutral position is a no go. Tried all the obvious things, tractor running/stopped, in gear/in neutral. I can easily shift from rear to mid or both without issue-simply can't get to neutral. Having to bypass ignition switch to start at the moment as there's a safety switch on top of transmission housing. Wondering if anyone has had the same issue and how it's to be fixed. Cheers, Erik
