These forums were helpful in guiding our purchase, so I wanted to give some initial feedback after the first few months with our B2601.
The B2601 so far has been a good size. I have no desire for anything larger. And I suspect a BX would have done almost all we have done so far. Maybe a little slower. Our main uses so far are lawn mowing, digging some stumps, planting trees, moving sand for kids sand box, planting 5 acres of food plot, dragging some big rocks, moving pallets around to clean up the yard.
TRACTOR
OTHER
Service Motor Company in Fon Du Lac, WI was great. We ended up getting a used one. The lead time for new kept getting pushed and seemed to be a big unknown. I don't mind delays, the lack of info was scary. I asked about used and and they got me a a quote for a 2019 set up exactly like we wanted new. R14, beat juice, remotes, etc. The price seemed very good and within 2 weeks we had our tractor for $4300 less. 50hrs and still had warranty left. Even with the initial delays, I was very happy with their communication. They are not the closest Kubota dealer, but I am happy we went with them.
Only problem. My wife has absolutely no fear of it and keeps mowing the lawn for me.
TRACTOR
- -R14 Tires: No issue with yard damage, other than where I spun the tires trying to dig out a stump.
- -60" MMM: Maybe my only question mark, size makes mowing parts of our yard a challenge. Some mulch and landscaping will help that. There is a little scalping on some "bumps" in the yard. Taking it off and putting it on is a sub 5min task.
- -60" Bucket: need a tooth bar to get it to dig into turf. But the large size will be nice when we get to the aforementioned mulch.
- -Loader: It doesn't pop stumps out as easily as I had hoped, but still a lot better than a shovel. When I have time I may look into adjusting pressures.
- -Size/Power: This has not been an issue. I feel no need for something bigger. Would it be helpful at times, yes. BUT, I like the smaller size for moving around our yard and trailering.
OTHER
- 60" Disk Harrow (Kin Kutter) - So far so good. Has a harder time with the soil at my property. Mostly due to the turf build up I need to kill. It pulled like a breeze through the sandy soil at my brothers yard. The 5' size has been a good compromise for both.
- Titan Stump Buster: It doesn't pop buckthorn stumps out with a single motion, but much easier than a shovel. Also does a good job digging 20"-30" holes for planting trees.
- Titan Pallet Forks: Easy to put on and adjust the width. Did knock a fork off trying to "Pull" a big rock. The big challenge will be moving some half full rain barrels, assuming it ever rains again.
- Land Pride Rotary Cutter: Minimal experience with this, but seems to work fine. (idle it down before engaging
- 18' Trailer pulled by GMC Canyon: This worked great. Did a 160mi trip across across WI and it pulled fine. Below the speed limit on hills, but nothing too bad. Averaged 14mpg. For the limited amount we will trailer, this will work fine. Have yet to have the brush hog and disc on it at the same time, but other than the hassle of loading that should not be an issue. Sure, bigger would be nice. But I like my smaller truck for the 90% of the time I don't need a truck, for the 10% I do, it works fine. (Watch the 2' drop on steep driveways)
