B2320 Transmission Squeals when driving
random
Nov 2, 2020
716
401
NC
6,981
Is that a statement or a question?
Like random said, this leaves us here at OTT little or nothing to go by.
You logged into OTT for the first time at 4:40pm, typed that and split.....
Many of us will try to help you, if you help us by providing information.
Is it new to you?
Does it move as it should (with appropriate force/power/speed), but just makes a lot of noise?
Is it an HST (hydrostatic drive)? Some B2320 are geared, some are HST...
NOTE: **If new to you and HST, there is a noticeable "whine" in many HST tractors. It takes some getting used to. Given the limited information, no clue if that's the scenario.** The HST noise can be improved with proper service and operation.
How many hours?
What's the service history?
What hydraulic fluid has been used in the tranny/hydrostat?
What hydraulic filters are on it? Are they painted gray? What brand?
What "range" is it in when it squeals? Lo/Hi or both??
Does it run fine otherwise?
Welcome to OTT.
Like I said, lot of smart guys and gals here. Many have B2x20 series tractors.
Ball is in your court......bring some details if you want help....
capp
BX2230 MMM, Fel
Oct 4, 2020
23
Lawrence Co., Ky
Need a little more info to help much. But by any chance is this a new (to you) tractor and is it HST? If so does it sound anything like this? https://www.orangetractortalks.com/...t-noise-more-of-a-screech-than-a-whine.48290/
If not, there's some people who can really help you here, but it would probably help if you could share something with the sound it's maki
Hi, if I was was you I'd buy me a new filter and some new oil first, do you know how long you have used your tractor since it's been serviced? It will hold 2 and 1\2 gal.
Bills B2320
B2320 with LA304
Nov 13, 2020
Lovingsyon Va
Thanks for the heads up. The tractor was serviced by Kubota Dealer 3 months ago with 4 gal Hyd oil 2 hyd filters. operation was (is great) except for the squeal that jus started. Oil- is full and clear.
I just raised the front and turned one wheel holding other , I belive one is making the noise. Does this make sience?
