B2301 starter relay? issue...
reamer
B2400, BX1500
Jun 6, 2018
56
Ashford CT
The 2301 won't start, turn the key and the seat safety relay system works, ( I hear the big "click ) and the pre heat works, turn the key to "start" and I get nothing... But I found if I run a jump wire from the stud (Blue arrow) and touch the tab (the red arrow) she starts right up. So, it's not the starter or that solenoid, What could it be and where is it located? Thank
You, Ron
BX23-S,57 A-C D-14,
6,335
ignition switch or what ever's between the 'start' stud of the switch and the starter 'start' lug. On the BX23s there's a 'starter relay' that the switch controls. need to see your wiring diagram...might be different.
3,189
The problem seems to be that there is NOT enough power being supplied to the spade terminal on the starter solenoid. So you can evaluate what the voltage is and probably how many amps are being delivered by the key switch and wiring. Or you can just start replacing parts and hope you get the correct one and that it is not the wiring. I recommend testing and then fixing the problem part(s).
There is also a way to install a relay (acts like a push button switch) that is activated by the “weak” power from the key switch.
on edit: added “key” in front of switch in last line.
