B2301 PTO stuck
7,093
Are you sure it’s in gear for mid, rear or both PTO’s? Only takes a little to pull them out of engagement.
Uiucbsme
B2301hst
Jun 18, 2022
10
Neither lever will move. As best I can tell, engagement lever is in the off position and the selector lever is in rear.
7,093
My apologies. Did not read your post correctly.
I would follow the lever linkage down to the case. I wonder if there’s a place in need of some penetrating oil and lubrication. While doing so, look to see if anything has been bent, damaged, etc.
My recollection with the smaller machines is the lever turns a shaft that goes into the case.
You may have to pull the left rear wheel to get at it well.
Have you used the PTO before?
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
101
Ottawa, ontario
Have a B2601 and exact same thing happened to me last year. Went to start and nothing. Found the pto selector lever was seized partially on. Spray every linkage you can find with a quality lubricant, I use the T40 Krown spray. The worst was the linkage coming out of the main case, totally seized as I didn't know it was hiding in there. Once all freed up give everything a spray a couple times a year. Easy fix once you know the problem.
Uiucbsme
B2301hst
Jun 18, 2022
10
Update: some penetrating lubricant solved the problem. Thanks for the suggestions.
7,093
Super! Thanks for posting your success.
I recalled similar issues, but thank heavens thebicman had first-hand experience…..
