B2150 stuck in reverse
B2150
B2150
Dec 25, 2022
Arkansas
Manual shift B2150 is stuck in reverse no matter which gear I place it in it’s still in reverse - any ideas assuming linkage came loose
5,554
I looked online kubota parts...if I'm reading the drawing correctly.. you need to take the top cover off, see what's 'bunged up', like the 'interlocker' plate....
mechanical stuff doesn't last for ever.....
B2150
B2150
Dec 25, 2022
Arkansas
Thanks for input going to limp
It back in reverse and check it out - is there a diagram online ?
5,554
I use Kubota canada, onlne parts.... other use 'Messicks' in the USA.
once you search for your model, I went to 'transmission' on left side, then the drawing is displayed with part number and, ugh, prices........
1,770
Kubota USA dot com has the illustrated parts list.
Kubotabooks dot com has the workshop manual
