B21 BH (BT751) off tractor servicing
joea
B21 TLB
Aug 2, 2020
97
9
Marbletown NY
Planning to reseal boom cylinder. The BH is in the "removed from tractor" position, which makes it a task to remove the boom cylinder.
The swing cylinders are out as I resealed them and figure it is easier to move the boom, etc, when they are not in the way. I expect to replace the bushings in several places, and maybe pins, as there is, to me, a lot of slop in the boom and swing frame. There appear to be bushings or other wear items in the areas of concern.
However, since the BH is sitting where and how it is, I find I cannot manipulate it properly to get the boom free from the swing frame.
So, I am faced with rigging up some ways to hoist the various bits, without (extreme) danger or any damage to hoses an fittings, or, to temporarily hook up the tractor, hydraulic lines only, to allow me to, hopefully, work the dipper stick and boom to where I can more easily lift and free them.
But, since I have the swing cylinder lines disconnected, I worry that there may be serious leakage past the control valves for the swing cylinders, or some other danger I am unaware of, when connecting hydraulic pressure to the BH.
Cleaning up a mess is one thing, blowing out those valves is quite another. Suggestions?
