B-7100 head cover gasket
Damolo
1980 Kubota B-7100 HST
Aug 16, 2024
11
Glasgow, Ky.
sylvanbanjos.com
I recently had to replace the head cover gasket on my 1980 B-7100 HST tractor. The part number for the gasket is 15381-14520. Problem is the gasket was too long by about an inch, so I had to trim it to make it fit. When a leak developed, I removed the gasket and reinstalled it with a gasket sealer. It had to be trimmed again, about 1/2" to make it fit. I'm guessing it may have stretched out some when I removed it? Could I have accidently stretched it in the initial install? Any advice much appreciated!
3,086
head cover gasket
I think he meant the valve cover gasket.
If so, when I replaced my B7100 valve cover gasket, (years ago) it fit perfectly, and still fit & sealed when I checked valve adjustment a few years after. Still no leaks.
Sounds like maybe you got the wrong gasket.
Anthony250f
20
San Diego
You are correct after googling that part number
Damolo
Aug 16, 2024
11
Glasgow, Ky.
sylvanbanjos.com
Thanks, Lil Foot, for your reply. Yes, I meant the valve cover gasket. In my Japanese Parts List book that came with the tractor they call it a "head cover" gasket, something lost in translation I guess. I do feel like it is the wrong part, but it's the one called for for the B7100. I suppose it's possible the engine has been replaced--I've only had it for 20 years--but it looks exactly like the D750-AH engine in my parts book. Is there a serial number on the engine that I can reference to see exactly what I have?
Thanks.
3,086
If I remember right, there is a cast number on the block denoting 650, 750, 850, & 950 engine sizes...
but I don't remember where it is.
My tractor is 150 mi from here, so maybe someone else can chime on here.
Maybe NIW?
