Allen Wrench Size, L2000
Eagleclaws
L2000 with a bush hog
Jan 13, 2018
Lumberton, MS, USA
Hopefully someone knows, I don't know the technical term for this so I will try and describe it.
On the throttle handle, at the point where it connects at the bottom, it goes thru a bracket, in the middle of the bracket is a piece that actually moves the throttle linkage. It has a allen screw that tightens it to the throttle handle so that as you move the throttle down it moves the linkage with a little bar that comes off of it. It is real loos but not loose enough to get off and take to the shop, I tried both my metric (1.5 and 2) and my standard allen wrenches and it appears to be between the 1.5 and 2 allen wrenches. Anyone know what size the Allen wrench is that fits. I can take a pic if you need me to. If you have had to work on it, you will know what I am talking about.
Thanks for your assistance, scratching my head.
3,095
What he said.
1.5mm = .059
2.0mm = .078
1/16 = .062
5/64 = .078
