Advice wanted -B9200 HST 4wd
michmike
B9200 HST D
Apr 18, 2020
Ionia, Mi USA
I need a box blade and found a good used King Kutter 5 ft'er that weighs about 500 lbs.
Can the B9200 handle one that heavy?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,058
Williamstown Ontario Canada
The spec's say 1,000# lifted at 24" back from the lift arm pivots so it should be no problem lifting the box blade.
As with any ground engaging implement, it depends upon what you are trying to do and how fast you are trying to do it.
Having the HST will help matching pulling power to the load.
Dave
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
General rule of thumb is five PTO horsepower per foot of cutting width. You could probably get away with it if you took it easy but a four foot cutter would probably be more appropriate. Your tractor has the lifting capacity but unless you have a loader it may get a bit light in the front end. You can get the numbers off of Tractor Data: http://www.tractordata.com/farm-tractors/001/2/7/1275-kubota-b9200.html
Oops - my bad. I saw King Kutter and thought mower as that's what I have. Box blade should be okay if you don't dig so deep the tractor stops.
