Those 3 rocks and a block just fit width wise with a couple of inches to spare. Being just wide enough keeps the load from shifting side to side. Tried gravel or dirt but the ruff terrain just caused it to bounce out and make a mess.
Depending on the unmentioned work the possibility of just turning around and backing up the hill could be an option if the FEL is in needed. Backing would put the weight on the front end.
One area I mow is 100' up/down and 1000' wide, it's a half bowl if you can picture that, backup in uncut grass and right back down the same track, rinse and repeat for two hours with that little 2350. Grade varies from 10% to 30%, left knee wedged in the steering column, left heel on the posi-lock, twisted right with the right hand gripping ROPS, right foot on the treadle pedal, and your butt still sliding off the seat. Fun times but I get paid by the minute. That's just two hours of 34 hours cut and maintenance time.
Maestro
