adding water to rear tires
jmyfld
L4400
Jun 3, 2016
Waco, Texas
I went to add water to the rear tires on my l4400 and discovered the fill valves were facing in. Do I need to turn the tires around in order to add water?
BX23-S,57 A-C D-14,
6,347
it might, year ago (2 ?) there was a major storm , cost billions....
google says....
Over the course of the year, the temperature typically varies from 39°F to 97°F and is rarely below 27°F or above 102°F.
so it DOES go below 32F where water frezzes....
5,782
If you want to fill the tires use windshield anti freeze and water or something else like RV anti freeze..Yeah I know it dont cold enough for long enough to freeze them up but mixed stuff, weighs more than water, I think I read that in here. Anyways jack the wheel up turn the valve stem to 12 O:clock and only put in enough to where the fluid comes back out when you take off the hose put the gut back in and pump it to the right air pressure and you are good to go
