Adding a hydraulic top link
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
68
Minnesota
Seeing the cylinder only moves a few inches and no need to move fast would 1/4"ID hose from the hydraulic control valve be sufficient.
Winkles_9
Kubota L3301
Jun 24, 2021
31
20
Annandale MN
Yes, 1/4" hose is just fine. That's what I have on my top link. It is still really fast. If you push the valve and the hose can't take the flow, it will bypass anyways just like when you reach the end of the stroke of the cylinder.
6,532
That would be an excellent choice for cylinder to outlet. Bigger hoses serve no useful purpose and make hose management more difficult.
MtnViewRanch
890
341
Lakeside Ca.
I'm assuming that you have or will be getting a 2" dia cylinder?
1/4" hose by itself will not slow the cylinder. An .030 orifice flow restrictor works perfect
I recommend 2, one for each end of the cylinder.
