Storing your Kubota? How to Prevent the Clutch from Rusting to the Flywheel
"Kubota recommends that when storing your equipment, have the clutch disc pressure relieved by way of placing a block under the foot board after the clutch pedal has been depressed."
Anyone got pics of this block and how to place it?
Also...
Condensation & Free Play Considerations
"Condensation in the clutch housing also creates a problem for the clutch disc. There is a drain at the bottom of the housing that should be opened from time to time to let water egress. If you have an early L175/L1500 and there is no drain plug, drill a small hole at the bottom of the housing to necessitate the removal of condensate from the clutch. Finally, clutch pedal “free play” should be adjusted from time to time as the tractor ages and the disc wears."
Any pics on where to dill this hole and what size hole?
Thanks,
Easychef
Also...
Thanks,
Easychef
