Well, I just recently upgraded my year old BX2360 to a B2920. I realized I needed a little more "oomph" all around. Don't get me wrong, I loved the BX, but wow... it's a BIG difference between the B and BX.
However, I am having one issue. I opted to go with the 31.5x15 turf tires instead of the 33x15 turfs. I went to mow the other day at 3.5" and I scalped the lawn! I had to raise the deck to 4" just to get a decent cut.... Here's what I'm thinking. The dealer had the deck adjusted based on the 33" tires and where the 31.5" are shorter in height, it has the deck cutting shorter. I measured the blades horizontal and parallel to the tractor and at 3" the blades are at 1.5". Also, the deck isn't raising enough for the holes to line up enough in the front stopper to place the pins in to keep the deck from lowering when brush hogging with the deck in place.
I've been reading in the manual, but I'm somewhat confused as to what all needs adjusted. Do I need to adjust the front link (front of the tractor to deck), along with the lift links connected to the sides of the deck? Do I need to adjust anything dealing with the rod that connects to the cat1 lift on the rear?
