50 hour maintenance
kubotabob
B2920, 60" MMM, FEL, Rear Blade
Aug 5, 2010
virginia, usa
hey guys,
I'm new to this site. I purchased a b2920 about about 7 months ago with the 60" MMM, FEL, and rear blade. I'm due for my 50 hour maintenance and was wondering how many of you did your own first 50 hour maintenance? For warranty purposes do i have to bring it to the dealer to perform the first one or can i do it myself?
thanks in advance
ETRon
M6040
Aug 4, 2010
128
Tellico Plains, TN
Just my two cents worth - I'm just about to my 50 hr as well. The maintenance isn't mandated to be done by the dealer according to my warranty. I don't think what my dealer charges for the labor end of things is all that much but I've always done my own so to speak and plan to do so with my tractor as well. The only thing, just common sense I guess is I'll be certain to save my receipts.
avi8tor
L2800DT, BX2380, RTV X900
Mar 14, 2010
101
Cleveland, Alabama
I performed my own 50 hr maintenance. It is more satisfying and you know how thorough you performed the maintenance rather than guessing or hoping your dealer covered everything. I asked my dealer if they would have to perform the maintenance in order to cover the warranty and they said no - the warranty would still be covered regardless of who did the maintenance. Most farmers around here do their own maintenance. It's simple and easy to do. Good luck which ever you decide.
JimBeard
Tiller ,6Foot Blade,FEL,3pointFinish Mower
Mar 1, 2010
40
Manchester NY
I do mine . B2320 i think yours is the same.
When you pull of the large filter on right side be prepared to lose about 2Qts.
of super UDT
RxDiesel
2007 L2800 HST
Oct 26, 2010
Fayette Co., Georgia
In the middle of doing it myself on an L2800 HST. Don't know about the Bs, but you can certainly do it yourself, and its good education on your tractor. I found grease nipples I didn't know existed, and mine gets little enough use that I had it 3 yrs. before reaching 50 hrs. My only real frustration was with having the right-sized sockets for unusual sized-plugs: 24mm for the HST tranny drain and 1 3/16th? for the 4wd front end fill, plus different-sized spin on filters requiring mutiple strap filter wrenches. My suggestion: check all sizes so as to avoid multiple trips to the tool/parts store!
avi8tor
Mar 14, 2010
101
Cleveland, Alabama
I didn't take my fel off - just raised it enough to get the hood up. Just make sure you are on level ground.
4,068
Un- fortunately a lot of dealers have gone to the Harley Davidson school of costumer relations,, By tell them that if you don't have ALL your maintenance done here by our highly trained and skilled tech, that will void your warranty if you do it your self,,
Do it your self, and become familiar with your toy, learn where everything goes and how it works, and when you wind up with an AWW SHYT,, (and you will) at least you have an idea what happened and how to fix it! If these guys in here came help ya then your in big trouble,
SO yes walk in to the dealer like you own the place and tell them I need,,X Y Z to do my 50, 200 hour maintenance and walk back out know,, that YOU CAN do it,,
ok Im done the coffee has just kicked in:eek:
