3 Pt Aerator Weights
kemosabe
Kubota L2501, 60" Box Blade, Front Loader
Sep 5, 2018
Houston, TX
I bought a 3 point aerator and now I am looking for water tanks to mount to the top of the aerator for added weight. Any suggestions on where to purchase? W 20" x L 22" x H ?
BigG
Sep 14, 2018
1,953
774
West Central,FL
What about the square water jugs you would by at the grocery. Might work if you do not use it very often.
jjgag60
washington, state
Wake boarders all use water ballast in their boats. they are not all hard tanks most are out of a PVC substance so check the sporting section for used water ballast.
gsganzer
49
Denton, Texas
I poured my own weights for my aerator, using concrete. I made one for each side and cast a lifting eye in each, so I could lift them to install/remove. I think mine weigh 250# each. You could make 4 smaller ones or any combination/weight.
