3 point ?
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,446
1,048
Minnesota
Is it bad to leave a implement attached raised while working on the implement?
timber and wine
L4802, loader, forks
Nov 1, 2026
41
37
NE WI
Its not bad for your hitch.
For safety you should block up the implement Or the lower arms while working on it. Same reason you don't go under a car without jack stands, and why you put safety bars on the loader cylinders.... Never trust the hydraulics to keep you safe.
Caden
1979 B7100
Apr 16, 2026
430
250
Not bad for anything except your safety. Best to chain it up or stick some blocks under there.
If you have to get under it, that is.
Bearcatrp
Mar 28, 2023
1,446
1,048
Minnesota
Don’t plan on doing anything under it. Just easier to work on it while lifted up. replacing the shoes. Old back doesn’t bend like it used to. More like rice crispy, snap crackle pop!
Grandad4
Apr 5, 2016
459
201
Greensboro, NC
If you're "replacing the shoes" on something like a box blade, you'd still have to raise it off the ground to reach under it, right? Put a log or some cribbing under it in case something happens while you're doing it.
