3 point hitch travel on bx2370
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
Look at the three point lever, then concentrate on the slot in which it travels. There may be a stop you can relocate located at the end of the slot. Loosen it, put it where you want it, retighten.
PaulL
2,578
1,544
NZ
It's quarter inching, not position control. The way you stop it going up any further is that you stop pushing the lever into the up position. It requires feedback between your eyeballs and your hand on the lever. :)
It's a pretty basic 3ph.
2,159
There may be a feedback rod between the short upper arm and the valve. It is generally used to limit the amount of up direction travel to stop the squealing of the bypass valve. I think it would be able to reduce the amount of up travel to some degree.
whitetiger
Nov 20, 2011
3,203
1,623
Kansas City, KS
That's what I thought Russell, just checking on here to see if anyone had made that adjustment.
Thanks for the response.
The 3-point control on a BX70 series is nothing more than a handle connected to a control valve. It is detented to the center so you pull back and hold it until the arms are where you want them, then you let go of the lever and it returns to neutral. There is no height adjustment whatsoever.
