3 point adjustment
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
I have been using my rear blade tilted to crown the driveway. When I adjusted the lifting rod to tilt the blade I went almost ½” beyond the groove on the bottom threaded rod and still did not see the groove on the top threaded rod. Since I had the blade on, I limited the tilt to the groove on the bottom rod. Today with the blade off I unscrewed the lifting rod and found the top threaded rod was screwed into the nut an extra ½”. To put it back together I started the upper rod one thread into the nut and then started the lower rod. With it assembled I now have an extra ¼” of extension at the lifting rod and this will tilt the lower end of the blade an extra ¾” inch down. :eek:
Tooljunkie
May 13, 2014
4,150
Mine is worn out. If i lift something heavy it seems to slip from time to time. Debating if i want to try to crank a new one on lathe. Seems like a lot of work when i could buy a generic one and make it fit.
I dont really crown my driveway, i pull ip the sides a little so water has somewhere to run.its about 500 feet and water prefers to travel down the driveway.
