2014 RTV1120D Dump bed problem
dkforge
L2501DT, BX2670 - (loader, MMM, snowblower)
May 10, 2014
9
North Central, PA, USA
Hi guys. I have a 2014 RTV1120D and the handle for the hydraulic dump bed would not move at all (yes the safety latch was pushed aside). In trying to get it to move the cable snapped right where it is connected to the handle behind the drivers seat. I need to raise the bed to replace the cable but can not figure out how to do so at this point. Is there a hydraulic hose I need to remove so I can manually raise the bed? If so which one is it.
Thanks for your help in advance.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
870
canada
With my 1100 C, the cyl is connected to the box by a pin, I think I would try removing the R.R. wheel and removing the pin. You will need to be careful as once you remove the pin, hose or whatever, the box will only be controlled by gravity.
