18" auger on BX25
evack757
BX25, Z421KWT-60
Mar 25, 2017
Suffolk, VA
I am a landscaper and love me BX25. It impresses me with its power everyday. But I need to see if anyone has some advise for a post hole digger. I am going to be planting 400 trees later next month. I will need a 18" hole about 18" deep for the root ball. Will the BX with a LP PD15 handle a 18" auger at that depth? I know the 12" is the biggest spec for the BX, but since I'm only going down 18" will it be okay? trying to avoid renting a skid steer if my BX will handle it. Thanks
bearskinner
Sep 1, 2014
926
241
N. Idaho
You might have to dig real slowly with that big of an auger, also depending on what type of soil your boring into. In this rocky assed ground a 9" for 6x6 posts is probably the max.
4,679
IM thinking that might be a tad on the big side for a 19 HP PTO
Brandonorr55
L3800
Aug 18, 2013
38
10
Missouri
I'm pretty sure that the BX would be way underpowered for that auger. The best option is to rent a Toro Dingo with the 18" auger. We did that last fall to plant trees with a 32" rootball, And the Toro was a lifesaver. Good luck!
bearskinner
Sep 1, 2014
926
241
N. Idaho
I know it's nice to bore a clean perfect sized hole, and looks professional, but if you have a couple HF tarps, and practice with the backhoe, you can do anything you need and not stress the equipment. After the tree is in, refill the dirt, and lift the tarp. That way there's not soil all over the lawn or sidewalk.
4,679
Your right check, big fingers and trying to type to fast :D
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
If you have too...auger a 12" and use a hand held post hole digger to make it 18"
I like the backhoe plan...
eng1886trk
2016 B2650, 60" bucket, QH15, RB1572, LR1572, BB1260, 42" forks
Mar 9, 2016
76
Lancaster, PA
I'd vote for the skid loader for the simple fact of how many you are doing.
While not 400, I planted 50 green giants and used a 24 in bit on a skid steer. Hydraulic down pressure would sell me over for your project for the simple thought of speed. Plus a skid steer is much easier to line up on a mark especially if it is something that is not in a straight line. We did those 50 holes in 30ish mins taking our time. I think if you had your stuff together, you'd only need a morning rental if you rental yard isn't too far away.
Just my two ¢
