How To Reset Error Codes on Utility Tractor w/ LED displays
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,193
1,178
E.
Mode "b" (Error Information Clear Mode)
1. While holding down both DPF INHIBT switch and parked regeneration switch, turn key switch "ON" or "START" position.
2. Mode selection display is indicated on the LCD.
3. Press the parked regeneration switch and the mode indication on the LCD is changed.
4. If "b" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Error information Clear mode is selected and the expression "PUSH" is displayed.
6. Press the parked regeneration switch for more than 2 seconds.
7. The expression "OFF" is displayed.
8. Turn off the key switch.
often works for me on many different models with LED displays and DPF
