PSA Check your Lug Nuts
johnjk
Apr 13, 2017
1,284
870
West Mansfield, OH
I had gotten complacent on checking my lug nuts after each use on my B3200 and it caught up with me this past weekend while cutting wood. During one of my water breaks, I glanced down at my rear wheel and though, man that nut looks loose and sure enough it was. I was able to freely spin it by hand. I hand tightened it up and headed back to the garage. Lucky for me only one nut on the rear was loose and all others were tight. Didn't take but a couple minutes to hit all with a torque wrench and verify they were snug. 110 ft/lbs rear and 70 ft/lbs front. Quick refill of my water and back out in the woods.
Take a moment as you go over your machines post work or after you top off fuel before heading out and check them nuts!
12251hd
M6800, L35, RTV
Nov 23, 2018
51
Woodbridge, VA
Good advice. I bought an L35 TLB and trailer as a package several years ago. Hooked up and headed out. About 30 miles down the road, one of the tandem wheels came off due to loose lug nuts; fortunately next to a boat dealer. Lesson learned.
johnjk
Apr 13, 2017
1,284
870
West Mansfield, OH
I guess I better check mine. I did use loctite on the rears when I installed the spacers.
I used loctite to attach the spacers but did not use any on the wheel lugs themselves when bolting the wheels back on. Change my operational routine. Add fuel, check fluid levels, grease/lube as needed, check air filters/filter screens, start up, check lugs, inspect wheels/tires/air pressure, get on and go have fun
3,226
Great service reminder. Now, here's another:
I have to admit that I misinterpreted the title of this thread. But since I'm here, I'll add the suggestion that you guys also have your PSA's checked so you can keep your lug nuts and keep tractoring along. :eek: Seriously, get it done.
OK, off my soap box. Carry on.
johnjk
Apr 13, 2017
1,284
870
West Mansfield, OH
Good point dirtydeed, and you may get lucky and be able to have it checked with a blood test now vs the old one finger salute!
Oliver
L2501, JD 3520
Feb 2, 2011
526
120
Preston County, WV
I used loctite to attach the spacers but did not use any on the wheel lugs themselves when bolting the wheels back on.....
Yeah I used it on the spacers then thought why not on the lug stems themselves? Unlike a car where you rotate the wheels, or my motorcycles where I'm always changing tires, there's no reason I know of not to put a drop of blue Loctite on the studs.
hope to float
L3450
Feb 18, 2018
467
60
Ireland
Not much fun but, deep breath and relax, and its done.
aaluck
Oct 9, 2019
928
746
Snowdoun, AL
Great advice...both. But as to the tractor lugs I had a front wheel fall of while bush hogging. Now I check constantly.
3,226
...had them all 2x. Biopsy was my least favorite :eek::(:(. Head in tomorrow for MRI. We'll see.
at least the lug nuts are tight, checked them this weekend. :D
Ping
BX2370-1
Dec 25, 2018
299
176
Troy, Ohio
All,
I know every case is different but, don't fear the finger! Been sufferin from old guy syndrome. Go all the time, etc. PSA test alone won't tell the whole story. Blood test, finger and biopsy needed for positive confirmation. My PSA was 4.0, finger negative, 9 of 12 biopsies positive, Gleason 7, 4+3 Had the surgery in June. Cancer was about to get out but, still in prostate. I got lucky in that regards, cancer free now. Trust me, you really don't want your plumbing reconfigured.
