Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 09-15-2019   #11
skypros
1st Yr. Apprentice
skypros's Avatar
Equipment: BX23s
Default Re: New bucket for SSQA conversion
Kubota Bucket ......... BX2448 ...... MSRP $411
Kubota SSQA ........... BX2410 ...... MSRP $434
skypros is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-15-2019   #12
B737
3rd Yr. Apprentice
B737's Avatar
Equipment: 2007 BX2350
I couldnít find this! Thank You!!
__________________
2007 BX2350
B737 is offline   Reply With Quote
Old 09-16-2019   #13
B737
3rd Yr. Apprentice
B737's Avatar
Thumbs up Re: New bucket for SSQA conversion
success!
with skypros help I found the SSQA bucket locally and picked it up, was $409.
The light duty pallet forks from Everything Attachments weigh about 238 pounds. I found light duty pallet forks from "Earth and Turf" in New Holland PA that weigh only 130 pounds. Once the EA SSQA adapter comes I will get a set from Earth and Turf. If anyone is curious they are listed as model# KSBX33U.
__________________
2007 BX2350
Old 09-16-2019   #14
JeepinMaxx
3rd Yr. Apprentice
JeepinMaxx's Avatar
Equipment: BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
My SSQA bucket came off a new BX2380 the local dealer had on the lot.
I installed the EA adapter Saturday. Loader pins came out easy
Moved my toothbar from my old bucket to the new bucket. Hated to drill the two holes, but I made sure to paint the bare metal before installing the bar
JeepinMaxx is offline   Reply With Quote
Old 09-16-2019   #15
B737
3rd Yr. Apprentice
B737's Avatar
awesome set up! came out great
__________________
2007 BX2350
Old 09-16-2019   #16
Journeyman
Equipment: BX23-S
same bucket as on my BX23S ! I used the 7, 5/8" holes on the btm frt edge to mount my toothed bar...
GreensvilleJay is online now   Reply With Quote
Old 09-16-2019   #17
JeepinMaxx
3rd Yr. Apprentice
JeepinMaxx's Avatar
Quote:
I'm going to use those holes for a Poly wear edge for snow removal
Old 09-20-2019   #18
B737
3rd Yr. Apprentice
B737's Avatar
for those of you thinking of doing this, a few considerations in addition. Kens hooks and BXpanded quick on hooks + brush forks will not carry over since the design is so different. The good news is, Ken has bolt on hooks for SSQA bucket and BXpanded has a new "quick on" brush fork system coming soon to the SSQA bucket.
The adapter plate from Everything attachments arrived today, took 4 days, awesome service from EA. I will prob head out to pick up the pallet forks from Earth and Turf next week.
https://earthandturfattachments.com/qa-fork-fits-bx/
__________________
2007 BX2350
Old 09-24-2019   #19
B737
3rd Yr. Apprentice
B737's Avatar
Follow up after picking up the Earth and Turf SSQA pallet forks. These are a perfect fit for BX. Light weight, but well built. Really nicely done, and great people to work with.
Was a nice drive out to New Holland too....
__________________
2007 BX2350
Old 09-26-2019   #20
NoBiffBetter
2nd Yr. Apprentice
NoBiffBetter's Avatar
Default New bucket for SSQA conversion
How much did these cost and could you send me a link or do they need to be purchased through new holland? If so I have a dealer right down the road so if you could give me the item or part number I can have them get me a set..
Currently I am using an EXTREMELY heavy set of forks.. they are made for a tracked skid steer so you can imagine how heavy duty they are.. I weighed them with my crane scale one time and found out they weigh 325lbs! Thatís a lot of lift Iím loosing! Itís a good thing I have my relief cranked to 2000psi and 400lbs is rear ballast lol.
How much does this set of forks weigh? I thought about building my own as they sell the frames on eBay and you just weld them to a coupler then buy the forks seperatly but I still think they would weigh more than the ones you have as those forks donít look solid but more so channel steel
__________________
2013 Kubota BX-2370 w/LA340 QA-Loader +Upgrades/Mods.
Long time vehicle/equipment mechanic.
NoBiffBetter is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
