I suggest you consider someone has repair the blower using non standard parts.The bolts that pass through the retainer and attach to the large drive gear have sheared. You can see the raw, broken end of one of the bolts in the drive gear.
I've been told that the two threaded holes in the retainer are for passing a couple bolts through to push the retainer away from the gear and slide it off the end of the shaft. Makes sense, but I don't want to do that until I have two new replacement bolts for the ones that got sheared off.
I'm not sure what to do about the square shaped key that sits in the groove of the shaft... does that have to come out first, and if so, how is it removed?
Looking at Messicks parts diagram for several versions of your blower, all I see is a $43 sprocket with two Allen screws securing it to the keyway and shaft not an industrial tapered bushing style sprocket.
Dave
