GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
If I do move it with the brake on, I do notice it pretty quick.
I also have an air ride seat so I can’t tilt it up to run the chipper.
The seat switch is a normally open switch, so I put a normally closed relay in series with it.
I added a microswitch to the parking brake to run the relay.
I also added a normally open switch parallel to the seat switch so I can run the PTO without sitting in the seat.
The relay is way bigger than I needed but I had it in stock.
