2025 Form 1040-V
Question follows, you can skip the drama straight to it below.
So... I bet many of you have been there. I can fix anything (or so my wife tells me). I bought a broken L35 as opposed to a working one to save some cash. The original story was that the owner had dumped the backhoe to do some 3 point work, pulled up to the house for a drink and bathroom, came out hopped on, and it would no longer move. Of course, the honest seller stated that it only needed a hydraulic pump and would be good to go. These things are indestructible.
When I bought it, the unit was sitting in the dirt and neither the power steering nor the transmission would work. The front bucket would go up and down slowly. So, I figured, yeah, I guess it could be a pump. I got it to my house and, nothing would work anymore. At this point the backhoe is still off. I started snooping around and found that the suction feed tube on the suction filter plate had a huge hole in it and was covered over with a piece of rubber hose. Apparently, (I assume) he had not applied oil to the filter and it was seized on to the plate. He must have tried channel locks or vice grips to hold it still and almost tore the pipe off. I had a hell of a time getting it off myself. I could not find a replacement so I had it repaired and put it back on.
Now I am back to where we were before, except that the power steering mostly works, but it is on a driveway not on dirt, and the front bucket goes up and down faster (not full speed) but still will not pick up the front end. I have changed the O ring at the transmission suction tube, the rubber tubes from the transmission pickup to the filter plate and filter plate to the feed tube, main feed to the power steering/gst pump, so I shouldn’t be picking up air.
Questions:
Questions:
- I have read on posts to check a sample of hydraulic fluid from the transmission. I bought a syphon with about 24” of tube and fed it in through the filler hole and nothing. No oil. The dipstick says full. Can someone with an L35 please tell me how long the measurement part of your filler gauge is? Maybe mine is a replacement and too long?
- Also if this is not how you are checking your sample please enlighten me or post a link to where this is already delt with?
- I could have two bad pumps, but barring the coincidental demise of two pumps at once doesn’t it sound like air in the system if everything is weak and no transmission movement?
- Has anyone with an L35 checked the pressures at the check ports (D, E, F in the drawing) on the transmission? Can you share with me where they are?
