In need of tie rod and ends L2002DT
RobL
Kubota L2002DT; Kubota FEL; Wallenstein Log Splitter; King Cutter 5' Brush Hog
Jul 14, 2017
15
Edmonton, AB
Hello,
I thought perhaps someone on the board would be able to point me in the right direction re: sourcing the following parts for an L2002DT, or a cross reference to part numbers for a North American model that is a match:
1) tie rod. Part Number 38380-4404-1
2) tie rod end (left) PN 38440-4487-0
3) tie rod end (right) PN 38440-4488-0
These are part numbers from an old Japanese shop/parts manual that covers this tractor, and if it helps, all three parts appear to be common to the L1802DT, L2002DT and L2202DT.
I have already reached out to TrevJ Enterprises and Whitehorse Distribution, as I am located in Canada. I thought I would put out an additional feeler while waiting to hear back from them.
Cheers and best regards.
R
RobL
Jul 14, 2017
15
Edmonton, AB
FYI, I believe I have located current part numbers for the tie rod ends via Messicks' website. The numbers above have been superceded.
Still searching for the tie rod itself.
RobL
Jul 14, 2017
15
Edmonton, AB
Thanks! The L275 seems to be the most likely match for sure!
sgec
L1802DT
Aug 13, 2023
Oregon
Did the L275 35290-43960 tie rod work as a replacement for the 38380-4404-1? Is it straight?
