I'm thinking the same thing.Diesel oil turns black much more quickly than gasoline engine oil. That part is pretty normal, even after 50 hours.
However, the clean oil in the filter seems concerning, at least to me. If the oil was dirty out of the oil pan but perfectly clean in the filter it seems like maybe the oil is not circulating through the filter as it should.
As @Bee-Positive suggested, a conversation with your dealer might be a good next move.
Thank you for the info.Could it be a defective oil filter that was pre-stuck in "bypass" mode?
Most older, and these smaller "non-emissions" diesels do soot up the engine oil sooner, which turns it black.
While your draining fluid, I'd suggest pull a drain plug on the front axle for a second ... If it looks good put plug back in ... If it's "bad" let drain and do the other side too ...
I've found that since there is no filter on the front axle, that the first "wear in" hours are pretty rough, and all that junk floatinf around in the "lubricant" can't be good for anything!
Yeah I'm with you on that one, you could've gotten better advise from the back of a cereal box.the motor would have blown by now. Not sure that I'm terribly comfortable with this.
You are under warranty. Either will cover if it blows .
If you still have this filter, it would be interesting to cut it open and see what's inside ... ?Oil in filter was very clean.
