I have a 2024 b2601 with R14 tires. I need advice on rear tire psi. Specifically for snow removal using FEL and mowing with 60 inch mmm. My tires are 6 ply R14s while older b2601 tractors with R14s used only 4ply with lower psi ratings.
I just plowed my 250 foot driveway with 24 inches of snow and it worked well with 500 lb rear ballast box with 25 psi in rear tires and 32 in front but spun tires on occasion in 4wd low. The snow was very deep, 2 feet and heavy.
Operators Manual , see picture, calls for 40 psi rear. I agree with close to max 34 psi on fronts using the loader but Rear psi seems excessive.
What Rear PSI do you recommend for snow removal?
What front and rear PSI do you recommend for mowing with 60 inch mid mount mower?
Thanks for any advice on this , especially if you have the same b2601/b2301 with R14s
