B7200 hydraulic steering
6,550
Haha - glad you're keeping an eye on this and thanks for the suggestion....same as what I posted as a question above at post #60. Makes me feel good when someone who knows stuff makes the same suggestion as me.
The distance between the knuckles
is critical to wheel alignment. Measure the length of the cylinder and the center to center knuckle spacing to see of thats even possible.
6,550
I assumed you had all of this worked out before buying the BX bits. As best I can tell Kubota B series tractors used the drag link and tie rod steering design paired with a an old school PS gearbox up until the B01 series (2018) when they switched to hydrostatic. Measure the length of your BX cylinder and compare to the length of the B7200 tie rod.
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
380
529
Baranduda, Victoria, Australia
Haha - don't assume too much. No, I didn't have it all worked out, just some rough ideas and figured I'd be able to make it work somehow.
Looks like it's back to Plan A.
Rather than just looking at it and speculating, I measured a few things....
The full lock to lock left to right travel of the steering connection in the green circle is approx 300 mm.
The full lock to lock forward and back travel of the steering connection in the red circle is approx 150 mm.
The full travel of rod in the double ended steering cylinder is 160 mm, and with the ball joints and tie rod ends fitted it's a bit more than 100 mm longer than the left to right steering link.
I won't be able to swap the left and right steering knuckles as the steering cylinder assembly is too long by a bit over 100 mm and it's travel is too short by 140 mm.
Back to Plan A....
The steering cylinder replaces the dashed yellow steering link with a ball joint attached at the red circle. It's travel is within about 10 mm of the full travel of the yellow steering link. I'll make a bracket that bolts between the standard BX mounting brackets and attaches to the chassis with another ball joint somewhere close to the clutch pedal end. I don't see any of this being overly difficult.
Hopefully some pics of the real brackets when I get around to making them might make more sense than the dodgy description above.
6,550
Haha - don't assume too much. No, I didn't have it all worked out, just some rough ideas and figured I'd be able to make it work somehow.0
Back to Plan A....
Thars pretty much what I expected.
I am goung to say this one more time and shutup. I think you will be miles ahead by ditching that BX cylinder and replacing the drag link with an aftermarket cylinder designed for that type of operation. They are cheap ($75-$150), readily available, and damn near trivial to fit. Thats exactly what you pictured earlier in this thread.
Paul Allwood
Jul 8, 2025
380
529
Haha - thanks. I've got the message. But mounting the cylinder I already have won't be very hard, and I already have it.
