Bx2660 snowblower size
Robono
Kubota BX2660
Nov 6, 2025
Mulmur Ontario
Hi everyone I have a Bx2660 and wondering what is the max width and weight 3pt rear snowblower should I use?
Bearcatrp
Mar 28, 2023
1,208
823
Minnesota
You want a minimum of width of your tractor. 3 point or front blower? Just bought a rear 3 point myself. My 1880 is 4 feet wide. My blower is 51 inches wide. Think these are made a few inches wider that the tractor it would normally go on. If you’re going larger, have to consider the weight. Am using a quick attach so my blower stick out back pretty good. So consider maneuverability of the blower too.
Bee-Positive
Nov 16, 2022
628
661
Amsterdam, NY
You can find the manual on https://kubotabooks.com/homepage/
Page G-46 & G-47 has the limitations for your BX.
It doesn't have a rear blower listed but I'd stick with 350 lbs. max front or back. If you're using a rear quick hitch you will want to subtract that weight from the total. For example: 350 total - 50 QH = 300 blower weight. As Bear said above a 51" width or there about fits pretty nice for the BX.
Note: the weight for the rear mount mower and disk harrow is less because they stick out farther and put more leverage on the 3 pt. like a long crow bar prying up and down. That's my opinion anyways.
Blue2Orange
Apr 3, 2025
354
253
Bayview Township
Also consider the pto hp spec of you snowblower. The SB1051(51" LandPride) notes tractor HP of a minimum of 18hp. The Traded down to the BX2380 this last Spring. The PTO is rated at ~18hp. Gross hp I think is ~23hp. Sure hope the 18 pto hp will be able to handle box deep medium moist snowfall.
