Turned it one time too many.
John T
2017 BX23S
May 5, 2017
1,051
518
under a rock
Pawnee
L2501
Jul 1, 2021
368
330
Ontario Canada
I can't see if that's the negative or positive but if it's the positive then vice grips are going to be a bit risky.
I would cross drill it right through the battery post and put a nut and bolt through it.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,730
2,072
Near Lancaster, PA, USA
I use an anti-corrosion paste such as Penertox, NoAlox, CU/AL Aid or the likes when making connections on batteries, grounds, crimps on vehicles. The surfaces are always cleaned first. I coat the cables before stuffing them into the crimp lugs or splices. When bolting ground lugs to steel, I clean the metal to bare and coat it well.
It may be useful to some that the side terminal batteries are tapped 3/8-16. With my own DIY studs, nuts and washers it allowed adding the thick 2/0 lugs for my winch/jumper connections.
