Blue2Orange
Time to decide on studs v. chains. Chains on rear only. BX2380 with 2" spacers and R4 26-12-12 tires. Checked out tirechain.com. Price was good relative to e what I recall for much larger and heavier chains need on the NH. So cost v. better quality studs is not a factor. Might still stud the front tires. People here noted not a good idea to chain the fronts.
The bottle jacks turned out to be both too tall
. Had to add a scissor jack to the collection. At least it was quick and easy to jack up the BX using the scissor jack. Lighter weight of the BX chains makes the effort to mount and remove a non issue. Only concern even with the spacers is the minimal space on the driver's right side wheel well. Just need to remember to routinely check the tension. And will add chain tensioner to the order if going with chains.
Diamond not studded chains are a bit more than 2 link ladder. But description claims 80% more durable than Rockwell 56 steel. Assuming other chains must be R56? Best on keeping the chains on top of the lugs.
2 link square alloy chains are a bit less. Description notes 5x longer life span and 32% more traction than trad 2 link ladder chains. The 32% more traction is significant.
Least expensive are the 2 Link ladder.
Due to the minimal clearance on the right side. Not going to try the studded chains.
Opinions? Leaning towards the 2 Link Square boron alloy chains.
