1998 b2100 steering issue
Bkiernan5
1998 b2100, 2004 b21, 1980 b7100
May 1, 2022
Dutchess county NY
Good evening,
My 1998 b2100 is pulling hard to the left. Everything is straight and nothing is bent, tire pressures are both the same, the hydraulic fluid is full and no leaks were observed. It turns very easy to the left but it is a bear to turn to the right. Any insight would be very helpful if anyone is familiar with this issue.
Shadetree605
kubota b2100
May 1, 2022
98
44
north little rock, ar
new here, as well as new to my b2100, but my little project turns ( by the steering wheel anyway ) real easy. have you inspected the knuckle bearings to see if any of the knuckle bearings are in need of replacing ?.
5,128
933
Jack up front axle and look for wheels that do not rotate easily and smoothly and also see how the steering works side to side with the wheels in the air.
Do the same with the rear axle looking for a wheel that does not rotate easily.
Bkiernan5
May 1, 2022
Dutchess county NY
Ended up being a damaged thrust washer in the steering hydraulic valve
