Zennoh l2201 shuts off after 30 minutes or so
terrywhitejr2000
Zennoh zl2201
Jun 2, 2016
Natchez, MS, United States
Hello all, I have a zennoh tractor and after 30 mins or so it just dies. It starts to lose power and then it will shut off and will not run correctly until I let it sit for 30 or so mins. Then it shuts off all over again. Any ideas or help would be greatly appreciated!
Sent from my SM-G935V using Tapatalk
2,171
Check fuel filter.... and or line from tank. You have a restriction somewhere
4,393
Try running with the fuel cap loose a few turns so air can get in. Cap may not be allowing the tank to breathe, creating a vacuum.
1,004
Have you checked how hot it is when it shuts down? I don’t think it has a gauge but you can use a hand held infrared thermometer and read a temperature on the upper block and radiator upper tank
