cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Looking for a few parts for a B348-7 mower deck, I picked up a nice used mower deck and it is in need of a part/s, I am looking for :
1. Hub/driven sheave pn 70080-00170
description- hub bushing that fits on blade spindle shaft at top of deck, The driven pulley fits around the bushing, The bushing has a key way and is split on on side .
Also looking for one sheave/pulley as one has a weld repair and although it seems ok I would like to replace it.
Note* The manual shows the model number as both B-348-7 and R-348-7 and B-348-6 R-348-6
Not sure if other size decks use the same bushing/pulley setup if anyone knows please feel free to reply
Val
respond thru this post or PM me
I have added a few photos to show what the sheave hub and sheave look like, The sheave(pulley) is 5" overall diameter, The inside hole measures 1 3/4" at the top and tapers to 1 5/8" at the bottom, The sheave hub is also tapered so that it will tighten into the sheave when the allen screws are tightened, The hub is slotted and has a keyway that accepts a key in the shaft, The shaft diameter is 1".
I am looking for 1 sheave bushing but would also like an extra so will buy 2 or 3 if available, I am also looking for 1 sheave as the one shown has a weld repair and although it looks like it will work I would like to replace it.
Val
