Winter time
Rigger Dave
L3301
Nov 11, 2016
25
Camden, NC
The tractor won’t be getting much use this winter. Planning to top off the tank and add stabilizer to it. Anything else I should be doing? Just hit 125 hours and she’s running like a champ!
Thanks in advance.
Dave
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
Toward the back of your owner's manual is a laundry list of things you could do, depends on your climate.. Includes such things as putting it up on blocks, taking out battery, etc. If winter is not too long a battery tender might be sufficient. For a common rail engine clean fuel is critical, so make sure your fuel stabilizer has a bacterial growth inhibitor in it.
4,051
Send the sum 'bitch up to NY where it can be worked moving snow!
Didn't you see that part of your purchase contract??:p
A battery tender is the only other thing I can think of.
Seriously, as long as tank is full, I think you should be good. How cold does it get there?
SidecarFlip
Banned
548
I'd put a tender on the battery or charge it and disconnect it for the winter.
4,393
You could just go out and start it and let it run for 1/2 hour each month. Let it move around a little bit, take it to the corner and back!
Rigger Dave
L3301
Nov 11, 2016
25
Camden, NC
If winter continues like it has lately, cold will not be much of an issue. The only real problem is the rain. My property gets wet in the winter and stays soft until late spring. Joys of living in the swamps of eastern NC!
Thanks for the advice. I'll top it off, put a charger on it and come out and run it every couple of weeks. The house will hopefully be done in January so it will make it much easier.
You guys up north bundle up!
Dave
2,170
Thanks in advance.
Dave
Ditto as to what Cat said - crank, start, run around the block - let it run for a bit (20+ minutes) and do it again......every week if possible - but a least once a month.
Freeheeler
b2650 tlb
Aug 16, 2018
704
521
Knoxville, TN
Not necessarily a winterizing thing, but if it's gonna sit for a while in a moist environment, you might consider lubing all the fittings and hitting any spots that need it with a spray can of paint.
200mph
Mar 3, 2017
1,228
59
PA
If your tractor has a clutch pedal, keep it in the depressed state so the clutch disc is not contacting the flywheel. There is usually a small clip on the fire wall to hold the clutch pedal in the down/depressed position.
johnjk
Apr 13, 2017
1,286
886
West Mansfield, OH
+1 on the battery tender. Hooked mine up yesterday afternoon after topping off the diesel. Wanted to fill my jugs up since it was below 2.70/gal. Here in OH we tax the crap out of diesel. Still looking for someplace that sells offroad diesel.
Anyway, I had to put a new battery in last August. Not expecting issues with it, but the battery tender will keep her starting good. Changed the engine oil&filter last week and will do the tranny fluid/filters this coming week. I'll follow that up with lubing all the zerks and then put her to work hauling firewood. Can't freeze up here fast enough for me.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
If it's not going to be used I'd change the engine oil.
Dirty contaminated oil is hard on internal parts just sitting.
Watchwldr
B2650, La534 FEL, Land Pride STB1072 Snow Blade, Home Made 600#Ballast Box
Jun 17, 2018
19
Coatesville Pa USA
Tax the crap out of diesel? My heart bleeds for you! Come on over here to PA and top off for 3.58/gal if you want to get a taste of taxes!
But I agree on the freeze-up. Can't hardly get into the woods to get firewood for next year yet it's so wet. But I'm not complaining. Better than a drought any day. Just ask the folks in California.
George
