Below is an email sent to my dealer. I would like feedback to be prepared for any questions or concerns. Thanks.
On Sunday, 2/12/2012, I was moving large (6' to 7') stumps to a burn pile. Several of the stumps were too heavy to lift so they were being rolled using the forklift attachment.
In trying to get another bite on the stump with the forks at the top of the lift and fully curled down a huge stump shifted and rolled back into the tractor. The tips of both forks were bent down about 45 degrees, the brush guard bent and damaged, and, as I found out later, the curl hydraulic cylinders were damaged.
The cylinder damage is such that the curl cylinders fully extend after about 10 minutes with the tractor not running. The weight of the forks pulls them all the way down.
I heated the tips and straightened them to go back to finish the job. The tips bent very easily again. A forklift repair shop said that the forks were likely ruined.
There may be other damage that has not been discovered. The fork frame seems to be OK but it has not been measured yet for square or closely inspected.
My question concerns my Kubota insurance. Can these issues from the accident be repaired/replaced under my Kubota insurance policy? I realize that there is a $250 deductible for the accident.
