What brand Rotella for L3400 HST
Grizz262
L3400HST FEL BackHoe
Oct 3, 2011
Hartland, MI USA
I think I made a mistake and put in Mobil 1 10w30 standard engine oil, fortunately I only ran it a coulple minutes to check the level.
What flavor Rotella DIESEL should I get?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,110
112
Hardisty, Alberta
Mobil one 10w30 standard will not hurt your tractor. It's specs far exceed anything a naturally aspirated ( non-turbo) diesel engine would require.
hodge
Nov 19, 2010
2,854
367
Love, VA
I'm no oil expert, but I disagree enough to say that I would get that oil out of there, fast. Gasoline engine oils may hold up, but their chemical characteristics will harm certain parts unique to a diesel engine. If it were mine, I wouldn't risk my engine for the cost of an oil change. I'd drain it and put a diesel rated oil in there.
As to the original question, I also use Rotella T 15W-40, dino oil.
eserv
May 27, 2009
2,110
112
Hardisty, Alberta
Mobil one is not a "gasoline" only engine oil. It has a "cf" rating, more than adequate for a L3400. But you can use whatever oil helps you sleep at night!
Ed
hodge
Nov 19, 2010
2,854
367
Love, VA
Ed
That I will. :)
Mobil 1's site says that their Mobil 1 10W-30 is for gasoline engines.
eserv
May 27, 2009
2,110
112
Hardisty, Alberta
I had promised myself before that I wouldn't get into any oil discussions on this forum so I'll let this go! Oil and fuel additive discussions are like discussing religion, everyone has their own opinion and by gum! they're sticking to it! ( NO religion discussed here either!!!!
Ed
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
I use Rottela- T 10 /40 in all my diesel engines Kubota , Cat and Ford Great oil
steve l
2 m9000,9540 all cabgmd700 kuhn 605m vermeer,r23a vermeer rake,468 jd baler,
Dec 29, 2010
77
bullard,texas 75757
rotella t 15 40 in everything 2m9000 9540 6320 jd 2955 jd l3650 210mf 3600 5600 ford 6080 ac 03 dodge 3500 01dodge3500 96 dodge 3500 94 toyota all have over2000hrs.96dodge 296000 miles 02 freightliner 862195miles toyota 234000 been very good for us.happy thanksgiving from east texas
